Code P0449 troubles 02 blazer 4dr 4wd
Old 06-01-2011, 11:05 PM
dweeber1's Avatar
dweeber1 is on a distinguished road
Default Code P0449 troubles 02 blazer 4dr 4wd
I ran the ODB system check and received the p0449 code. i have bench tested the vent solenoid located in the rear and when it's disconnected air moves through, when it's connected, it's closed. so i think that it's fine.
I checked the sensor connectors on the canister purge valve (near the throttle body) and it has power. i don't know what else to do to bench test the purge valve or if i need to replace it or the vapor canister.
Thanks,
chris
ComputerNerdBD
TrailBlazer GMT360/GMT370 (2002-2009) Tech
07-12-2014 05:36 PM
Clancy Pell
11-08-2013 01:36 PM
superfly851
04-16-2013 06:56 PM
brian400ex
03-10-2013 07:15 PM
joejiz
18
11-14-2012 03:31 PM
Quick Reply: Code P0449 troubles 02 blazer 4dr 4wd
