4wheel drive vacuum line diagrams?
Old 06-22-2007, 09:33 PM
kakn's Avatar
kakn is an unknown quantity at this point
Default 4wheel drive vacuum line diagrams?
any one have a good diagram or know where to find one on the net for a 91 blazer? i found out today that there are two vacuum lines missing from where they connect to the transfer case. there are suposed to be three vacuum lines. i have one running to the actuator under the battery but dont know where the other two would go. i also have one line running from a T on the back of the motor that runs down to where the 3 vacuum lines would go but dont know which one to plug in. the third line i have no idea where the hell it is or where it went. any help or pictures would greatly be appreciated!!!
Old 06-30-2007, 12:37 PM
DetroitMuscle is an unknown quantity at this point
Default RE: 4wheel drive vacuum line diagrams?
+1
Old 07-12-2007, 04:28 PM
ss85monte is an unknown quantity at this point
i had the same problem on the 87. i have a 91 now. right where they meet together is tricky. i could take a picture if youd like.
Old 07-12-2007, 09:52 PM
kakn's Avatar
i got what i needed finally. A POSI LOK KIT!!!
after i did some testing with the vacuum lines and found out i hooked the line from the intake to the vent hose " lots of cool smoke from the exhaust from burning the fluid id assume" i decided to go the posi lok route. just need to install it now.
Old 07-22-2007, 09:14 AM
I installed my cable yesterday(throttle lock cable from a caterpillar impliment)but I need a cable connector for it to work right. I will take pics of what I did already and post em for your reference, I did follow a cable routing for the real posi lok and found it quite unnerving following them. I hid my cable end in the center console box so its unseen and has plenty of cable travel to lock up the front diff.
shawn95
Engine & Internal
11-23-2010 06:35 AM
Kerias
Engine & Internal
02-28-2010 08:19 PM
missu
02-23-2008 10:55 PM
lowester
04-06-2007 09:30 AM
chrissy
11-15-2006 10:54 PM
Quick Reply: 4wheel drive vacuum line diagrams?
