93 blazer dies while driving
Old 10-05-2005, 03:43 AM
nickaf7172's Avatar
nickaf7172 is an unknown quantity at this point
Default 93 blazer dies while driving
My 93 blazer dies while i am driving. It just shuts off and the brake sticks to the floor, i lose my steering, and my battery light comes on. When it dies the radio is still playing. i turn off the truck and let it sit there for a couple of minutes it starts back up then dies again. If i let it sit for a few hours its starts up like nothing happened. This has happened to me twice in three . Please can someone tell me what is going on.
Old 10-05-2005, 04:55 AM
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: 93 blazer dies while driving
I'd say check your ignition coil, ignition control module, distributor cap, rotor, and fuel filter.
Sometimes when the truck gets hot, all the trash in that filter will gum it up. Next time it does it, tap on the filter and the bottom of the gas tank and see if that makes a difference.
While the truck's running, carefully pull the boot off of the coil wire and see if the coil is firing, if it is, make sure it's a white/blue spark and not red.
The ignition control module will also cut the truck off when it gets hot if it starts to go bad. Those can be tested at your local AutoZone, just have to get to it. It's plugged into the top of the distributor.
Those are all places that I'd start. Start small and work your way up.
Old 10-06-2005, 03:36 AM
Hanr3's Avatar
I am thinking it is your fuel pressure regulator.
You brakes, battery light, and power steering do what they do becuase the engine died.
10 to 1 says you don;t have any codes either. How much mechanical skill do you have? If not much, might want a shop to do this one.
tammyjcks
03-29-2020 10:05 PM
cavired99
07-01-2014 09:59 AM
cavired99
05-12-2014 10:27 PM
Joecrack85
07-22-2012 12:17 AM
sindy1232
08-22-2008 09:38 AM
Quick Reply: 93 blazer dies while driving
