Bolt head size for 2000 LT 4x4 front shocks?
Old 09-21-2007, 12:33 PM
filtalr's Avatar
filtalr is an unknown quantity at this point
Default Bolt head size for 2000 LT 4x4 front shocks?
Posted this below in general and then saw the "post in appropriate subsection" post (oooops).
Anyway what is the proper wrench size for the front shock bolts on a 2000 LT 4x4? I fit a 3/4" on it but it seems just a bit loose - is it metric? Don't have a that big of a metric to check with... would hate to round it off as it is a bit stubborn [:'(]
[align=left] [/align]
Old 09-21-2007, 12:50 PM
Default RE: Bolt head size for 2000 LT 4x4 front shocks?
I believe it is 18mm which is ~0.746 inch... It is close enough to use a 3/4" socket, but an open ended wrench or 12pt box end wrench may be pushing it if you have to apply a ton of force to get it apart.
Old 09-21-2007, 01:27 PM
filtalr's Avatar
Thanks for the speedy reply - the 3/4 sockets are 6 point so I may give it a try <fingers crossed>
Old 09-21-2007, 01:35 PM
Actually, sorry, I screwed up my conversion... 18mm == 0.708" so there is a bit more of a difference. 19mm is very close to 3/4". I mistakenly typed 19mm when I converted it...
So yeah, you'll want to try and find some 18mm wrenches or sockets. Sorry for the confusion.
Old 09-21-2007, 03:24 PM
filtalr's Avatar
Well the 3/4 six-point worked for getting one side off -- I'm inside cooling off before putting it back on (93 degrees here in OKC today) going back for the other as soon as I'm ready
Old 09-21-2007, 09:13 PM
filtalr's Avatar
Got 'er done ... with only one scrape and one slightly smashed fingernail - not too bad all things considered. Also did a little recon for my next adventure - replacing the front wheel hubs (there will be a new thread on that soon). Overall the 3/4 six-points worked ok - just a little on the loose side. Those flaps protecting the engine compartment on top were a royal PITA - felt like cutting them off but instead folded them up, in and out of the way for the most part - problem was they were so brittle they nearly broke off anyway.
bigdaddykane93
14
05-08-2014 08:54 AM
ksunday1
Suspension Tech
06-12-2013 07:12 PM
echo1
15
08-28-2012 07:56 PM
01Blaze218
10-13-2011 10:05 AM
jagblazer01
04-16-2009 03:54 PM
Quick Reply: Bolt head size for 2000 LT 4x4 front shocks?
