98 Blazer won't accelerate
I own a 98 Blazer LS with about 67,000 miles on it. I just bought it a few months ago and everything was fine until a few days ago when I got on the highway and it was very hard to accelerate. If I let of the gas a little the engine would get fuel but as soon as I would press on it a little harder it wouldn't do anything. After I pulled over and looked under the hood for a few minutes it started up and ran fine for a little bit and ended up doing the same thing. Also, I've noticed that a few days prior it has been hard to start. I'm thinking fuel filter.....any suggestions?
RE: 98 Blazer won't accelerate
Im having a similar problem right now, it feels like its holding back, i let off the gas and then get back on it and it goes fine. i thought it could be fuel or air filters?
I'm pretty sure its not my air filter because I couldn't go over 20 mph. I'm hoping its just the fuel filter because replacing the pump would be horrible timing considering the holidays are coming.
If you haven't changed the fuel filter for a while it's not a bad idea to do so. When you change the filter, tap out the fuel onto a white rag and see if you see any black in the fuel. Black in the fuel filter is an indication of wear in the fuel pump ( black carbon brushes)
Changed the filter and I still have the same problem. The acceleration problem only happens after I drive for a little while. If I stop the truck for a minute it drives fine and eventually happens again. Also, when I pulled the old filter I notced lots of black in my fuel line.
amazing!..im having the same prob on my 97. feels like the converter is locking up and when i shut down the vehicle it unlocks till i get to like 40 mph. the 4.3 feels like its straining against the converter.
MXer746
06-06-2011 02:34 PM
marrand3
11-11-2009 05:01 PM
Jer12
03-28-2007 07:11 PM
budiblazer
06-21-2006 09:57 PM
