2000 s10 with the po300 problem
Old 11-28-2007, 06:20 PM
levi's Avatar
levi is an unknown quantity at this point
Default 2000 s10 with the po300 problem
well as we all see the 4.3 has problems. well a few months back i water lock motor in a flood. did everything safe by pulling plugs and drain oil gave it a week to dry out before i tryied to start. well everthing went good truck started fine.
so i did a complete tune up,cap,rotor,wire and ac delco rapid fire,fuel filter, air filter, clean throttle body(took off). also had to replace tps and iac(twice).(i work in small auto repair shop) used modis from snap on to diaganose my problem.
ok now my problem is code po 300. check for vaccum leaks, check fuel pressure,check injector balance. so i again replace cap rotor wires plugs again still problem. now last wednesday the truck spuddered bad big loss of power. the the day the truck ran great had no problems no miss ran like new.the next time i got in to drive it went back to running bad and missing. i have done seafoam in the gas and oil.
i hope this info helps and ideas or suggestions would be great.
thank you
Old 11-29-2007, 11:32 PM
Hanr3's Avatar
Default RE: 2000 s10 with the po300 problem
did you check your tranny fluid?
got water in your cat, exhaust system?
Old 11-30-2007, 02:04 AM
blzR's Avatar
blzR is an unknown quantity at this point
Levi, don't forget to clean out your EGR valveand PCV.
How deep was the water level on your Blazer? Do you think it entered the intake area?(hydro lock/connect rod issues)
Pgrego04
11-21-2011 12:17 PM
High_Speed
09-22-2010 10:05 AM
High_Speed
09-21-2010 09:16 AM
das96blazer
02-22-2010 11:11 AM
dragynaz
02-22-2008 09:15 PM
Quick Reply: 2000 s10 with the po300 problem
