No 4x4, 4 button switch doesn't light up!
Old 12-06-2007, 08:45 AM
dooser's Avatar
dooser is an unknown quantity at this point
Default No 4x4, 4 button switch doesn't light up!
99 Blazer LS 2dr 4x4
It all started when I shifted into 4x4 lo in some snow, and it would shift back to 2hi. After playing around rolling in reverse in neutral it shifted back. Then my Service 4wd light intermittently came on. Well now it comes on all the time, and the 4 Button Electric switch LED's don't light and the Service 4wd light is on all the time when running. I would have tried reading the codesfor the TCCM but pin 13is empty on myDLC connector.[&:]
Anyways I'm at a standstill with this.
Any suggestions.
Old 12-06-2007, 12:50 PM
Chevy Lover's Avatar
Default RE: No 4x4, 4 button switch doesn't light up!
Check your 10amp 4WD fuse in the interior fuse panel.
Old 12-07-2007, 11:52 AM
dooser's Avatar
Ran across a shop manual and I was reading over the Encoder Diag. It says When DTC Sets the Service indicator will be on, all shifting disabled, the shift lights will be disabled, and the next time system is powered on the TCCM will power up as if the 4HI was the mode present when powered down. I don't know if this helps anyone. Just thought I'd throw it out there!
Old 12-08-2007, 03:38 AM
Any luck? Are you sure you were in 13?
[IMG]local://upfiles/2910/D7605E46B21C4004ACAC67A79EB03E0A.gif[/IMG]
Old 01-22-2008, 07:02 AM
dooser's Avatar
ORIGINAL POST:
Any suggestions.
2ND POST
Ran across a shop manual and I was reading over the Encoder Diag. It says When DTC Sets the Service indicator will be on, all shifting disabled, the shift lights will be disabled, and the next time system is powered on the TCCM will power up as if the 4HI was the mode present when powered down. I don't know if this helps anyone. Just thought I'd throw it out there! [align=left]
[/align][align=left]CURRENT POST[/align][align=left][/align][align=left]Hooked up a TECH 2 Scanner, and Pulled a DTC C0327, for the Encoder Motor. I was hoping that it was the Switch. I haven't replaced it yet, but as soon as i finish checking the wiring to rule that out I will update the post to let you know the outcome.
[8D]DOOSER
[/align]
Old 02-06-2008, 09:19 PM
va454ss is an unknown quantity at this point
I have the same issue.
I've hooked up a Tech 2 scanner, but am unable to retrieve any codes. It does say that a DTC is present on the ATC. It gives me the option to clear the code. As soon as I do, the service 4wd goes out and immediately comes back on.
I have a new encoder motor and had tried to install it prior to getting access to the Tech 2. The new encoder motor engagement slot wasn't in the same postion as the arm on the transfer case.
I moved the transfer case arm and installed the new encoder motor. I started the Blazer and had no forward or reverse, so I must assume I was in the neutral postion. I tried to move the engagement slot on the encoder motor to match the arm on the transfer case, but it wouldn't budge.
If I plug in the new encoder motor without it being attached to the transfer case, will it move it to the right postion?
Old 02-10-2008, 04:31 AM
Anyone?
762mm
15
08-28-2023 03:32 PM
Flyfishen
06-18-2019 11:22 AM
Stoober
10-15-2014 03:21 PM
lazer2000
09-16-2012 11:16 PM
tdannar
12-06-2009 10:10 PM
Quick Reply: No 4x4, 4 button switch doesn't light up!
