Torsion Bar Crank Tutorial
Old 01-15-2008, 09:33 AM
a_tack's Avatar
Default Torsion Bar Crank Tutorial
Moved to the Tech Article (DIY) section:
How-To: T-bar Crank
Merged Discussion from this thread into:
How-To: T-bar Crank - DISCUSSION
Old 11-18-2009, 10:52 AM
odfareal's Avatar
odfareal is on a distinguished road
Links in thread appear dead.
Old 11-18-2009, 11:00 AM
The link to the Article was in fact dead, but the lower one worked. It is now fixed.
Old 01-05-2010, 04:09 PM
BIGDAVEEVADGIB's Avatar
BIGDAVEEVADGIB is on a distinguished road
when you crank the tortion bar how much wear dose it put on the u joints and how is the ride
Old 01-05-2010, 05:31 PM
I doubt you will ever find a number associated with how much more wear occurs after a t-bar lift. There are just too many contributing factors to actually quantify it.
As far as how it will ride, it will definitely be more truck like.
Old 01-05-2010, 06:03 PM
Spectreblazer's Avatar
Banned
i talked to a master tech about this and he said as long as a front end alignment is done after the t-bar crank you should not have any problems. i imagine wear is still gonna increase.
Old 01-05-2010, 07:23 PM
It will most definitely be harder on your ball joints and CV shafts.
Old 01-05-2010, 07:33 PM
Banned
a front end alignment would help out a little though right?
Old 01-05-2010, 07:39 PM
It would help keep your tires from wearing out faster, yes. It will not correct for the angle change though and the angle change is what will accelerate the wear on the ball joints and CV shafts.
Old 01-05-2010, 07:44 PM
Banned
alright.
Quick Reply: Torsion Bar Crank Tutorial
