axle hub nut torque spec??
Old 03-21-2008, 06:20 PM
myblackblazer's Avatar
myblackblazer is an unknown quantity at this point
Default axle hub nut torque spec??
98 chevy blazer4.3 4x4 4dr does anyone know or know where i can find the torque spec for my axle hub nut i need to do a lower balljoint and dont wanna just zap it back on with my impact gun. also has anyone ever heard of a mildto bad vibration from the rear between 50 60 mph and the speedo needle shakes while it does this and the other gages are fine any intel would be greatly appreciated
Old 03-21-2008, 06:27 PM
Default RE: axle hub nut torque spec??
103 FT LBS
HERE is a list of all applicable torque settings for the front end.
Old 03-21-2008, 06:34 PM
thank you for the specs this hopefully makes the job go a little smoother
Old 03-22-2008, 10:26 AM
WolfPack's Avatar
How do they settle on all these torque values...I mean 103?? I guess 104 ft/lbs was just too tight..might strip a thread, but 102..yep that sucker would work itself right off the axle
Old 03-22-2008, 10:34 AM
The 103FtLbs is from the conversion from metric - 140Nm == 103FtLbs. The torque value is a baseline value calculated from the number of threads engaged, the diameter of the threads, and the loads associated with the connection.
Old 03-22-2008, 10:36 AM
WolfPack's Avatar
Ahhhh so there's a formula! I feel better about GM now..no arbitrary values
Old 03-22-2008, 07:40 PM
Well, atleast that is what I do... It also highly depends on the two materials.
Old 12-11-2009, 09:33 AM
isnms's Avatar
isnms is on a distinguished road
Originally Posted by swartlkk
103 FT LBS
I know this is an old thread but you seem to have the answer I am looking for but the link is now dead.
Is this information still available?
edit: I think I found it -
https://blazerforum.com/forum/general-tech-help-7/torque-specs-4164/
or
https://blazerforum.com/forum/general-tech-help-7/front-wheel-hub-bearing-change-6504/
Old 03-22-2011, 04:41 PM
BAM1369's Avatar
BAM1369 is on a distinguished road
How much damage can you do to the hub if it is over tightened?
yuka42
04-28-2014 07:45 PM
BlazerRaider
06-02-2013 11:51 AM
benthm7
06-11-2011 12:37 AM
Iceman_19
14
10-27-2009 07:33 PM
2001Blazer4x4
03-02-2005 10:45 PM
Quick Reply: axle hub nut torque spec??
