temp Gauge gets hot, then cools down after a bit.
Old 01-18-2006, 02:28 AM
scn1010's Avatar
scn1010 is an unknown quantity at this point
Default temp Gauge gets hot, then cools down after a bit.
K i own a 78 K5 with a fairly new block, when I head out the Hot/Cold gauge will go all the way up after driving for about 7 mins, it usually doesn't stay on hot too long then goes back down to the middle like it normally should, I am just worried about the engine all of a sudden saying its hot like that then going away. is that something to worry about??
Old 01-18-2006, 07:08 AM
Default RE: temp Gauge gets hot, then cools down after a bit.
Sounds to me like the thermostat is sticking shut, then popping open at an unusually high temperature. I would replace the thermostat (maybe $5) and see how it goes from there. Make sure that you get all of the air out of the system before you drive it for any extended period of time.
Old 01-18-2006, 11:01 AM
scn1010's Avatar
hey thanks, I'm goin down to checker today to grab some mud flaps so I'll snag a thermostat while i'm at it.
Old 01-18-2006, 09:53 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
ORIGINAL: scn1010
And maybe a ten foot ladder to get into that beast.
Old 01-18-2006, 11:42 PM
Jman's Avatar
Jman is an unknown quantity at this point
I hope your not putting the mud flaps on that beast, It just wouldn't look right.[sm=noooo.gif]
Old 01-19-2006, 02:39 AM
scn1010's Avatar
hahah yeah I'm only tossing them on to pass inspection, the real question is how to pass emissions! they said I failed both tests for emissions, running too rich. I put a new Edelbrock carb on this last summer and have no idea how to tune it so I can pass.[:@]
Old 01-19-2006, 07:35 AM
I'll have to see what I can find. How do they run the test? You could probably lean out the idle circuit and get it to pass, but depending on what carb you have, the idle screws might be in different locations (maybe not though). It's been awhile since I have messed with an Edlebrock (carter) carb.
Old 01-19-2006, 10:59 AM
scn1010's Avatar
If I sent you a pic you think you could pinpoint where those idle screws are?
Old 01-19-2006, 11:14 AM
scn1010's Avatar
oh sorry they run two tests I believe for two different types of somethin?? hydrocarbons?? **** I dont know. All I know is that its running too rich! they do a test running at 25mph and the other I think is at idle
Old 01-19-2006, 12:57 PM
Just need to know the model number of the carb.
Dadatone
07-26-2012 12:28 PM
zakm0n
01-09-2011 07:31 PM
Luvthyblazer
04-25-2010 06:03 PM
muddin84084
08-04-2009 06:55 PM
JVS
06-12-2005 11:00 PM
Quick Reply: temp Gauge gets hot, then cools down after a bit.
