2000 LS Tow Package?
Old 07-06-2008, 06:39 AM
kearney99's Avatar
kearney99 is an unknown quantity at this point
Default 2000 LS Tow Package?
I have a 2000 LS Blazer. How do I know if I have a towing package? I bought it used.
It did have trailer wiring behind the step bumper, but no connector. (I installed one and installed a Class III hitch reciever recently)
Is there a suspension mod which would indicate a Tow package?
What is included in it?
Thanks!
Old 07-06-2008, 07:37 AM
Default RE: 2000 LS Tow Package?
Do you have the factory hitch? If so, then you have some semblance of the "tow package". For the S-series trucks, there was no true "tow package" that included everything necessary to hook up a trailer and go. There are many RPO codes that deal with trailering provisions.
UY7 Wiring Harness: Heavy Duty, Trailer
UB1 Wiring Harness: Light Duty, Trailer
VR4 Trailer Hitch: Weight Distributing Platform
Z82 Trailering Provisions, Special Equipment, Heavy Duty
RPO Z82 ties the HD options together, but isn't necessary to show that the vehicle came equipped with those HD options. Even RPO Z82 did not include the plug at the back. My old Bravada was equiped with Z82 and I had to add the plug.
Old 07-07-2008, 09:20 PM
kearney99's Avatar
No, not the factory hitch. What is the difference between the HD harness and the light duty? Brake wire? I have that.
I'm looking to tow a pop-up trailer with a GWVR of just over 2,000 lbs.
Should be no problem, no? I towed my Jeep ('43 ******) on a U-Haul type car carrier int he beginning of June from NJ to Reading Pa for a WWII event. On the way home, it overheated and I found a crack in the rad. Replaced the rad and it runs cooler than before, but I'm now a little tow-shy...
Kevin
Old 07-07-2008, 10:18 PM
The HD harness included all of the wires for a 7 pin plug including being pre-wired for an electronic brake controller.
2000lbs, you shouldn't have any problem. Just remember to drop it down into 3rd if it starts to hunt for a gear.
mattjphoto
05-31-2011 10:16 AM
cochran07
Lifting Tech
17
02-20-2011 08:47 PM
Bberry20
09-17-2009 03:17 PM
blazerJim1701
15
07-24-2009 05:54 PM
blazerJim1701
07-08-2009 08:31 PM
Quick Reply: 2000 LS Tow Package?
