Service Parts ID Tag in Glove Box
Old 10-17-2008, 09:29 AM
wienerdog's Avatar
wienerdog is an unknown quantity at this point
Default Service Parts ID Tag in Glove Box
Inside the glove box door of my 99' Jimmy is a sticker thatreads the VIN and'SERVICE PARTS IDENTIFICATION Do Not Remove' then AJ1 ANL AN3 and 60some others like that. What is it? What is it for and how to decipher it?
In another post I read that the rear end gear ratio is listedsomewhere in the glove box. If so, I cannot find it.
Hereare the first 13 numbers/letters in theVINof mymy 99 Jimmy:
1GKDT13W8X254xxxx
Old 10-17-2008, 09:40 AM
Default RE: Service Parts ID Tag in Glove Box
The SPI label (also called RPO label) is what tells you all of the options that your truck came with.
Search for RPO and you should come up with the decoder or three.
Old 10-17-2008, 10:01 AM
z28jeff is an unknown quantity at this point
Yeah, just google rpo decoder, and you'll most likely find what your looking for. The rpo codes are sort of the build recipie for your truck. The engine, tranny, color, interior trim package, etc. are all identified in those codes.
Gear ratio codes start with a "G" (except G80, which is locking diff). Most non ZR2 Blazers had 3.42 gears which is GU6 IIRC.
Oh yeah, and LMC has a nice vin decoder....
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=11
p72lwor
16
05-12-2008 11:43 AM
Blazin_Jason
12-05-2007 10:17 PM
jagblazer01
08-31-2007 06:23 PM
Zygoat
04-03-2007 01:54 AM
2FAST4U
08-12-2005 02:30 PM
Quick Reply: Service Parts ID Tag in Glove Box
