clunking on bumps
Old 11-07-2008, 03:50 PM
daxsteel's Avatar
daxsteel is an unknown quantity at this point
Default clunking on bumps
[align=left]I have a loud clunking noise only when I go over bumps, coming from my front end driver side . It almost sounds like something is loose. I thought it was the idler arm and changed it, but still the noise persists. One thing which I think it might be is the inner diff axle bearing. The seal is leaking slightly, but not dripping oil, and the axle has a little play it it. I hope its not that because of the amount of labor involved jus to fix it and would like to know for sure. Does anyone have any ideas what could be making this noise? if it is the inner axle bearing? or could be something else?
thanks for the help.
98 blazer
4x4
100,000 miles
[/align]
Old 11-07-2008, 05:26 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default RE: clunking on bumps
blown shock/strut
Old 11-07-2008, 06:02 PM
2002XTREME's Avatar
ball joints!!!!!!!!!!
Old 11-07-2008, 06:39 PM
daxsteel's Avatar
[align=left]Thanks for the help, I replaced the shocks 4 months ago. I will check the ball joints tonight and see if they are loose.
[/align]
Old 11-07-2008, 08:52 PM
Dew2008 is an unknown quantity at this point
CHECK THE CONTROL ARM BUSHINGS!!! I had the same issue on my driver side, I replaced shocks, ball joints, tie rod ends and then I looked up and seen the bad bushing. $8 fix and the noise is gone. Just a though man. Hope it helps!
Old 11-08-2008, 03:07 AM
WolfPack's Avatar
x2 on the balljoints
Old 11-08-2008, 10:14 AM
portcqb's Avatar
One other thing to check is the shock bolts since you mentioned changing them. I get a clunk from a loose shock mount. I need to take it apart and put some locktite because it clunks on some bumps. Go back around on the front shocks and make sure they are tight. If not then it probably is the ball joints.
Old 11-08-2008, 12:53 PM
ORIGINAL: portcqb
I had the same experience after changing out the shocks on my old Bravada. The bushing portions on the replacements were not as wide as the originals which required more tightening of the mounting bolt to squeeze things together.
Old 11-08-2008, 12:56 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
Torsion bar mounts??
Old 11-09-2008, 09:44 PM
wienerdog is an unknown quantity at this point
How about hood hindge arraching bolts?
TSB # 01-08-63-001
dbleobarbie
11-15-2013 11:39 AM
musclecar70sfan
11-07-2010 08:48 PM
BrokenBlazr
02-26-2009 08:16 PM
Nick Bain
02-25-2009 03:58 PM
bobbyj42
05-13-2008 12:45 AM
Quick Reply: clunking on bumps
