95 blazer 4wd indicator lights - Simple Question
Old 11-19-2008, 04:13 PM
BIGGER_HAMMER's Avatar
BIGGER_HAMMER is an unknown quantity at this point
Default 95 blazer 4wd indicator lights - Simple Question
Hey All,
I have a New (well new to me) 1995 blazer.
I read the owners manual but it did not give a clear answer, so time to Go to the Pros!
I have a simple question about the four wheel drive system indicator lights.
I have the three button system (2 Hi, 4 High & 4 Low) When I push the "4 Hi" or "4 Low" switches, the pressed switch lights up and stay lit.
However when I go back to "2 Hi" there is no light. Should this switch be light or stay lit under normal driving?
If it is not lighting, is this an item that I can repair?
BIGGER_HAMMER
Old 11-19-2008, 07:26 PM
WolfPack's Avatar
Default RE: 95 blazer 4wd indicator lights - Simple Question
Yep it should stay lit. If the other two work, I'd say you just have a burnt out bulb/LED..cant recall which is in the 4wd switch.
Old 11-21-2008, 02:00 PM
trouty31 is an unknown quantity at this point
I have the same thing going on with my "new to me" '95.
I figured that the 2 Hiwas supposed to be lit because at night, those buttons are too hard to see if they are all dark.
Is this a common bulb that can be picked up anywhere?
Marcin
10-27-2013 08:02 AM
SL5417
01-23-2013 12:43 PM
adaptechsolution
04-07-2012 12:03 PM
mudsliner
11-26-2006 12:56 AM
4WDBlaze
Engine & Internal
10-20-2005 12:05 PM
Quick Reply: 95 blazer 4wd indicator lights - Simple Question
