94 s10 blazer motor swap help?
This is actually my first time on any forum a close friend told me it was the best way to get help doing this.
I have a 94 s10 blazer with avortec 4.3 and i was wanting to swap the motor with a 97 4.3 out of a 97s10 blazer i was wondering if the wire harness would match up or if i would have to replace it?
also i have takin out the rear drive, shaft transfer case, and transmission to where i can see the torque converter and back of the motor i was wondering how exactly do you get the motor detatched from the motor mounts to where i can take the motor out with an engine lift....
any help would be great!
Thanks,
Charlie
Thanks,
Charlie
RE: 94 s10 blazer motor swap help?
have to change complete harness pluss tranny and fuel pump and all computers and abs system you need 93-95 engine. You can use the block but that is it
He could use the long block and swap the intakes right?
no the heads are different
i cant help you with the fitting or anything
but i DO know that in a 97, which i believe is a 2nd gen
you will have to take the front bumper, radiator, and core support
off to pull the motor out of the front. it wont come out unless you do
im sure you already knew that
but you can get to the fron mounts if you take all that off
the back mounts i dont have a clue
hope i helped =]
-steven
hope i helped =]
-steven
I have a similar issue here. I have a 1995 with a blown motor, crank and bearing went out. Now the local salvage yard i've been dealing with sold me a 1998 s-10 blazer motor to install in it. The heads seem to be the same? The valve covers are the same. The distributor has the plug wires coming out of the left and right as does the 95 motor. He did offer me a 96 motor but the plug wires came straight out the top of the distributor cap. I have been informed by many a mechanic that its imposible to install the 95 intake and distributor into the 96 with the plug wires going up instead of left to right? So the yard man sugested that we locate another motor. We found a 1998 4.3 v-6 with the plug wires coming out of the left and right sides of the distributor cap. I understand i may have to change the oild pan and the intake. But everything else seems to be in check? Please if anyone else has come across this before please feel free to contact me asap. Thanks
That is one stupid yard owner/operator... Why would you even consider doing something like this? You could have quickly and easily found this information in other threads stating that you cannot/should not do what you are proposing. I can say with a lot of certainty that you will have intake manifold gasket problems doing what you are proposing. You would be much better off reusing the heads from the 95 motor as they will atleast bolt on as is without hacking up things. Sure you can open up holes and force things to go together... That doesn't mean that it will last at all. Why would you put your reputation on a jerry rigged mess such as you have proposed??? Just ridiculous.
LesMyer
38
01-09-2020 11:45 AM
94BlazerGirl
08-28-2014 06:14 PM
