front axles seal
Old 03-09-2009, 04:25 AM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default front axles seal
1999 S10 Blazer 2 door auto 4x4.
What tools are required to replace the front lip seal on axle tube. I know how to remove cv axle but what is need to replace the seal. Plastic hammer work to install seal. What tool to remove seal.
Old 03-09-2009, 08:25 AM
A screw driver will remove the old seal. If you are good with a hammer, you can install the new one that way. I will typically find a large piece of steel or something else to use for installation. If you have some large sockets (roughly the same diameter as the seal where it presses into the axle tube), they will work good.
Old 03-09-2009, 09:54 AM
Logan's Avatar
Did mine last week. Bought a seal puller for $10, and used a 2x4 and a hammer to install new seal.
Old 03-09-2009, 06:46 PM
blkblazer's Avatar
Default axle seal.
Thanks.
What do you think about cardone cv axles. Good quality or garbage.
Old 03-10-2009, 08:21 AM
Logan's Avatar
Cardone makes some nice stuff, so they should be fine.
Old 03-10-2009, 09:58 AM
bandidolenny's Avatar
I just installed Cardone cv shafts in my blazer. To me they just looked better than the "made in China" shafts that I just pulled out after only about 17K miles. My vibration in the front end seems to have gone away as well.
Old 03-10-2009, 05:34 PM
blkblazer's Avatar
Thanks much.
litterbug
03-07-2011 09:14 PM
roycet4
09-21-2010 07:28 PM
thewickedk5
08-08-2010 01:36 PM
218persuader
23
10-09-2009 07:24 AM
webbyj883
Suspension Tech
09-09-2005 02:15 PM
Quick Reply: front axles seal
