Can You still tow with a body lift?
Old 06-19-2009, 02:50 PM
Baker99Blazer's Avatar
Baker99Blazer is on a distinguished road
Default Can You still tow with a body lift?
Iv heard that with a 2 inch BL you wont be able to tow..is this true?
Old 06-19-2009, 02:56 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i dont see why you wouldnt be able to.
Old 06-19-2009, 03:21 PM
sky96744's Avatar
sky96744 is an unknown quantity at this point
Yes you can still tow with a body lift. I tow all the time with no problems
Old 06-19-2009, 03:58 PM
bandidolenny's Avatar
The problem with a body lift is that you have to cut the bumper in order to fit it around the frame at 2" higher.
After installing the 2" raise brackets, my solution was to simply move the bumper rearward by one hole in order to keep it intact. I have towed a 3000lb trailer with no problems with this set up.
Or you can do like Sky96744 and install a receiver hitch...
Old 06-19-2009, 04:23 PM
sky96744's Avatar
Good catch bandidolenny, I tow with a reciever. I didnt set my bumper back up to allow for towing. I wouldnt even try towing with just my bumper after installing the 2 inch body lift.
bandidolenny did a custom setup to allow him to tow off the bumper.
Old 06-19-2009, 04:56 PM
NVANZEE's Avatar
you dont want to tow with the bumper unless you find a way to make the brackets stronger
davtak
06-28-2011 08:47 PM
mattjphoto
05-31-2011 10:16 AM
cochran07
Lifting Tech
17
02-20-2011 08:47 PM
blazerJim1701
07-08-2009 08:31 PM
WMU10
Lifting Tech
10-04-2008 09:52 PM
Quick Reply: Can You still tow with a body lift?
