1998 Chevy Blazer 4X4 problem
Old 07-06-2009, 06:37 PM
bcn's Avatar
bcn
bcn is offline
bcn is on a distinguished road
Default 1998 Chevy Blazer 4X4 problem
Blazer will not shift into 4 hi or 4 lo. 4 hi button blinks and goes back to 2 hi. Tried disconnecting battery, but same issue after reset. Checked wires at TCCM, but seem okay. What is bad? TCCM?
Old 07-06-2009, 08:00 PM
3-button or 4-button 4wd dash switch?
Old 07-07-2009, 05:18 AM
bcn's Avatar
bcn
bcn is offline
3 button
Old 07-07-2009, 05:37 AM
billymac49's Avatar
billymac49 is on a distinguished road
the computer sees that the transfer is not completing a shift. can be mechanical or electrical problem. encoder motors are known to go bad.
Old 07-07-2009, 09:18 PM
Before you assume the encoder motor is the problem, run through the proper testing. Start with getting the codes from the TCCM (OBD2 Non-Automatic Transfer Case Diagnostics). It could be corrosion at the encoder motor. It very well could be an encoder fault, but it is easy enough to check the codes.
Old 08-13-2009, 08:04 PM
Katmandu's Avatar
Katmandu is on a distinguished road
Question
I just bought a 99 Blazer a couple hours ago with this same problem. Mine has the 3 button switch.
#15 Fuse keeps blowing out (for the 4x4).
What does TCCM stand for ??
I assume the encoder motor is which does the actual shifting in the transfer case ?
Old 08-14-2009, 10:37 AM
TCCM == Transfer Case Control Module
It is the brains in the 4wd system. It is located behind the passenger front kick panel.
Stucker92
04-26-2014 08:06 PM
FPetro
11-04-2011 10:48 PM
walkingtall
10-08-2006 07:19 AM
Quick Reply: 1998 Chevy Blazer 4X4 problem
