Computer Codes
Old 04-21-2006, 01:40 PM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
Default Computer Codes
How do I reset the computer codes in my 97 Blazer? I think that when I ran my engine without the battery, I corrupted the codes in my computer. Possible? How do I at least check the codes and where to look them up to see what they mean?
Sorry if this topic was brought up already, I can't find it.
Thanks in advance
Old 04-21-2006, 03:22 PM
Default RE: Computer Codes
Reset the codes by disconnecting the battery for 5-10 minutes. This will clear everything out of the PCM.
To check the codes, you either need an OBD2 code reader or a trip down to your local Advanced Auto, Autozone, Napa, etc. Most auto stores now do free code scans, many will give you a print out of the codes and some will even clear them for you.
I have an AutoTap Scanner that works with my laptop for reading codes and examining sensor data on all OBD2 vehicles with the enhanced data pack for GM vehicles. I use their code definitions whenever I need help with a code that doesn't already have a description in their software. You can simply search through their database to get the description. You may have to know some of the digits from your VIN to get the exact code due to manufacturer and model specific code definitions.
Here's the link to their database:
AutoTap OBD2 Code Database
Good luck!
Old 04-21-2006, 04:39 PM
KA3AX's Avatar
I can't drive the car, it will not even start! Is there a way to reset the computer in the Blazer?
Old 04-21-2006, 04:56 PM
Reset codes == Reset computer
Just disconnect the battery.
Old 04-21-2006, 05:20 PM
KA3AX's Avatar
Okay, thanks!
abig84
01-05-2012 08:23 PM
abadinalbany
04-16-2011 11:31 AM
bigjoewebb
01-27-2009 09:36 AM
mikeesho1
10-26-2007 12:31 AM
drperry
07-04-2007 04:25 AM
Quick Reply: Computer Codes
