transmission swap: 4l60e to turbo 350
Old 09-27-2009, 07:42 PM
quinn1991's Avatar
quinn1991 is an unknown quantity at this point
Default transmission swap: 4l60e to turbo 350
My 4L60e is slipping moderately bad, so Ive decided to replace it instead of having it rebuilt... again. My initial idea was to swap it out for a manual, but the amount of work and bit of custom fabrication necessary has discouraged me, so I'm just throwing in another automatic. A friend of mine is going to sell me a THM 350 for 100 dollars, everything included, I'm sure that it will bolt up same as the old tranny, however I do have a few technical considerations before I blindly buy it. Mainly, what are the ramifications from putting a non electronically controlled transmissions in a truck that is designed for one, will my torque converter function normally with the new transmission, and is there anything else that could go wrong that I'm not anticipating?
Any help or advice would be greatly appreciated, thanks
Old 09-27-2009, 08:03 PM
There is A LOT of work to go from an electronic automatic to a non-electronic automatic. First, you will have to have the PCM reprogrammed to keep it from complaining about the missing transmission. Hopefully the TH350 has the proper provisions for an electronic speedometer pickup, if not, you will have to get a manual to electronic conversion box. Then you will have to connect the kick down cable. Get a longer driveshaft. After all of that, you may still have bugs to work out.
Old 09-27-2009, 08:32 PM
abig84's Avatar
crossmember will have to be moved too
Old 09-27-2009, 09:28 PM
fst450's Avatar
fst450 is an unknown quantity at this point
not to mention no overdrive. I did a 5 speed swap was simple. better fuel milage to.
Old 09-27-2009, 09:31 PM
quinn1991's Avatar
wow. alright, thats for telling me that. looks like im just buying a new 4l60e.
tech180
02-02-2013 10:23 AM
ChevyBoii91
12-22-2012 01:22 PM
Keith Epicwin Warren
02-16-2012 02:56 PM
chris015
09-17-2011 07:31 PM
an240172
09-07-2009 02:58 AM
Quick Reply: transmission swap: 4l60e to turbo 350
