97 Blazer Turn Signal Indicator lights stay on
I just finished a front end conversion and both my turn signal indicators light up when I turn my headlights on. The dash lights blink when I use the turn signals and the exterior lights all work like they are intended. I have checked my ground wires on the radiator support and they seem to be tight. The turn signal dash lights are fine until I turn the headlights on then both indicators light up. I think is has to be a ground but does anyone have any ideas?
Update
Well I found that if I run a new ground to each turn signal, the dash indicators don't light up any longer. I also found that after a couple miles you also have smoke from a bunch of wires burning under your dash. On a positive note, my gas mileage went up with the help of the tow truck! This is why I need a new hobby ha ha, still waiting to hear what the damage is going to cost me.
All better now
Well I got my Blazer back, and it turns out that both front turn signal bulbs had filaments that were shorted together which caused my indicators on the dash to stay on. The turn signals were working though. The wiring that went up in smoke was an after market remote keyless entry that was tied into the light circuit. So if your dash lights stay on and your lights outside are still working, check your bulbs.
ta3ff
10-14-2009 05:07 PM
shaka1111
02-13-2006 02:23 PM
