Towing Capacity
Old 11-12-2009, 08:08 AM
blazingon's Avatar
blazingon is on a distinguished road
Default Towing Capacity
New to the post so hope I am doing this correctly. I have a 2002 Blazer LS, 2-DR, automatic. The trailer weight in the manual says 5700 LBS, the GCWR is 9500 LBS, my car weighs (with passengers, cargo, gas, etc.) a total of 3,910, the door panel says GVWR 4450 LBS and my axel is 3.42. So, what size trailer could I tow? I have been researching this until I am blue in the face. Some say I can pull no more than 4,000 LBS, while others say 5,000 LBS. with an excellent towing package (which I don't have right now). Don't want to spend the money if I can't pull anything with my Blazer. I have been looking at the Trailmanor lite trailers and the other ultralite trailers which are usually under 3,000 LBS with the standard equipment (no AC or other extra cargo). Should I forget about towing anything? Thanks.
Old 11-12-2009, 08:50 AM
rriddle3's Avatar
Easy, GCWR 9,500 - GVWR 4,450 = 5,050.
Old 11-12-2009, 08:55 AM
Exactly! 5,000 pounds is the max trailer weight (trailer + cargo) that you should haul given that you have a hitch installed that can handle that weight.
bluefever
16
07-23-2014 02:41 PM
jshultz78
12-10-2012 09:52 PM
Shain3777
10-19-2012 07:26 PM
the_boz
08-07-2011 03:57 PM
lonerider
01-16-2010 12:24 PM
Quick Reply: Towing Capacity
