trans won't shift and speedo doesn't work
Old 11-20-2009, 03:35 PM
bigdawgz2006's Avatar
bigdawgz2006 is on a distinguished road
Default trans won't shift and speedo doesn't work
K I fixed the engine not starting issue. Now the last thing is the lack of a speedometer and trans won't shift gears while driving. The speed sensor is plugged in and so is everything else on the trans. I have to have missed a ground but can not find one loose anywhere.
Does anyone know where this might be?? Or what the issue could be?
Old 11-20-2009, 08:15 PM
abig84's Avatar
sounds like the speed sensor to me. maybe it went bad? see if the truck will shift manually. like put it in first. get up to like 3000rpm then pop it in second.
my 93 doesnt have the vss hooked up and thats what it does.
Old 11-21-2009, 02:44 PM
Yep, bad VSS sensor or bad wiring to the VSS sensor.
S10BlazerFTW
06-16-2013 03:35 PM
guitarman1961
04-07-2013 08:00 AM
ineedatowel18
06-28-2011 04:46 AM
ImScrewed92
Tires and Wheels
25
01-31-2010 04:12 PM
coupster
07-19-2009 11:16 AM
Quick Reply: trans won't shift and speedo doesn't work
