Fresh air vent problem? 99 4x4
Old 12-10-2009, 06:20 PM
lllewis87's Avatar
lllewis87 is on a distinguished road
Default Fresh air vent problem? 99 4x4
I have a 99 blazer 4x4. The heater insnt working as it should, it doesnt blow very warm air. I have tried changing the t-stat and flushing the heater core, the core is free of obstructions. The other day while waiting in the parking lot for a friend, someone in another car parked beside me was smoking a cigarette and i could smell it just as if she was smoking in my truck (my windows were up and my heater was running) I was wondering where I could located the fresh air intake on this truck. PLEASE HELP!
I found some info on an air intake vacuum actuator, does anyone know where to locate this actuator?
Last edited by TripleBlackBlazer; 12-10-2009 at 06:54 PM. Reason: Consecutive posts
Old 12-10-2009, 06:55 PM
The HVAC system draws outside air from the outside except when in recirc mode. The air is drawn in from the top of the cowl (above the firewall). Recirc mode is only available when the a/c is on.
Now your problem is likely a failing or failed air temperature actuator which is an electronic actuator that controls the blend door (or air temperature door). The actuator is located on top of the HVAC housing and accessible by dropping the glove box down and out of the way. The blend door controls air flow over the heater core.
Search should turn up quite a few threads discussing this.
This schematic shows the function of the air temperature actuator:
RIFLEMAN 308
02-13-2012 07:39 AM
haha29
02-10-2010 05:53 PM
BlackBlaze
05-17-2007 08:13 PM
myboo11009
08-22-2006 04:21 PM
ljrce
Engine & Internal
07-17-2006 12:02 PM
Quick Reply: Fresh air vent problem? 99 4x4
