four wheel drive problem
Old 01-06-2010, 12:37 PM
petethepig24's Avatar
petethepig24 is on a distinguished road
Default four wheel drive problem
i have a weird problem with mt four wheel drive, i push the button, i hear the click in the right side, so i know the module works and i hear the tranfer case shift(both into hi and lo) but it doesnt engage, some one told me it could be a vacuum switch, but before i change parts i figured i ask you guys...any ideas? thanks in advance
Old 01-06-2010, 12:42 PM
nj4x4blaze's Avatar
Sounds like the vacuum switch is getting stuck. Just remove it and clean it out. The switch is located on your transfer case and you'll see 3 hoses going to it.
Btw thanks to Kyle for the above picture. I'm currently using this to clean out my vacuum switch.
And if you are still having problems, then remove your battery tray and check the Vacuum Actuator, they are known to go bad as well.
Old 01-11-2010, 08:13 PM
ssfligg is on a distinguished road
My 2004 Blazer was not going into 4 Hi, i traced the vacuum lines and jiggled some wires and now it works. I found the vaccuum line in your diagram, line B, which you have vented to atmosphere. This line is sucking in air, like a working vaccuum in all modes, 2wd, 4 low and 4 hi. That does not seem right and I was wondering if it was normal.
gml
01-03-2013 11:02 PM
gmoney30
01-19-2010 10:49 PM
chevy98
04-02-2009 02:41 PM
myronhntr80
12-07-2006 02:06 AM
missu
03-15-2006 01:36 AM
Quick Reply: four wheel drive problem
