2002 blazer Valve tap---- intake leak
Old 02-07-2010, 02:54 PM
gunnysarge's Avatar
gunnysarge is on a distinguished road
Exclamation 2002 blazer Valve tap---- intake leak
my wifes 2002 blazer just started what sounds like a valve tap. 1) can the lifters be adj.? she uses 5w-30 oil could 10w -30 help with this?
Also while looking this over I noticed coolant coming from the front corner of the intake, she told me shes had to add coolant a few times . Could one be causing the other????? I don't see water/coolant in the oil ..
Any help???
Old 02-07-2010, 03:41 PM
I have seen a few collapsed lifters and even a few bad cams in these engines. The rocker arms are not adjustable, but it wouldn't hurt to pop off the valve cover and check the torque on the retaining bolts.
I would get that LIM gasket fixed up sooner rather than later. It won't get better.
Old 02-07-2010, 04:40 PM
gunnysarge's Avatar
Thumbs up valve tap
Thanks Ill look at the bolts and Ill get the Intake manifold Gasket fixed ASAP...
Old 02-15-2010, 11:29 PM
TsMachine is on a distinguished road
Feeling your pain Gunny, just had the same thing happen here on the drivers side so started riping into it today. So far no fun.....
stinz
05-19-2013 10:31 PM
milehigh
08-30-2012 01:36 PM
HorrorxHotel
07-10-2010 08:22 PM
bigpar Blazin
04-15-2007 04:08 PM
Lucky614
01-31-2006 10:23 AM
Quick Reply: 2002 blazer Valve tap---- intake leak
