Head Bolt Torque Specs. and Sequence
Old 01-10-2011, 08:17 PM
rcravincase's Avatar
rcravincase is an unknown quantity at this point
well, i took my heads in to napa to get checked out and rebuilt. they automaticly ordered the head bolts when i called back. i forgot my list at work. i would never reuse tty bolts either. id prefer to upgrade to reusable, but thats not very cheap. and the passenger side is going to be fun to tighten accuratly. its tighter than i thought on that side
Old 06-01-2011, 11:11 PM
dirty420's Avatar
dirty420 is on a distinguished road
Originally Posted by Ryanmatt135
http://img341.imageshack.us/img341/82/cylinderhead.png
First Pass In Sequence - 26 ft-lbs
Second Pass In Sequence - 44 ft-lbs
Final Pass In Sequence - 66 ft-lbs
so does that mean your doing all the bolts in each sequence? not just the med for the second and long ones for the last ?
Old 06-02-2011, 06:22 AM
Ryanmatt135's Avatar
That means all the bolts in each sequence.
Old 06-02-2011, 12:04 PM
dirty420's Avatar
thanks ryan ^5
Old 06-02-2011, 12:36 PM
85evo's Avatar
85evo is on a distinguished road
I have a 2000 blazer with a 4.3 just got done replacing the head gaskets. Now engine won't start it spends but don't seem to have compression. Checked timing and all marks are right on the money. The only thing I can think of is that I have a connector without a home. This connector has 2 wires 1 yellow and 1 black its on the drivers side and coming out of the main wiring harness. Any ideas?? HELP!
Old 06-02-2011, 01:30 PM
dirty420's Avatar
they should all just fall in to place pretty much . well atleast they do on my 97 . just keep looking. i can let you know later after i get home from pulling mine apart
take a picture of it
Old 06-03-2011, 10:05 PM
85evo's Avatar
it comes out of the main wiring harness, it's not part of the air filter system nor throttle body. It's closer to the driver's side as you can see on the picture.
Thanks for your help
Old 06-05-2011, 06:08 PM
pheaton's Avatar
pheaton is on a distinguished road
This is excellent information, good question to the OP and awesome accurate response from Ryan. Can you rep on this forum?
Old 07-08-2011, 01:09 PM
horsepowr's Avatar
horsepowr is on a distinguished road
Originally Posted by brians1bad72
I have a 2001 Blazer 4.3l looking for torque specs and sequence for the heads. I am im the middle of the job right now. Thanks.
I had to go to the GM dealer to get the correct sequence and torque for mine, but my son has the specs right now. You do start out with 22Ft.Lbs first round, but the second and third rounds you will need a Degree Tool for this 2001 the Model, so be carful about where you get your info. The specs have changed on the later models. Also GM recommends that you replace the Head Bolts with new ones for this Model.
Last edited by horsepowr; 07-08-2011 at 01:13 PM. Reason: Forgot to add new bolts.
Old 08-11-2011, 06:29 PM
reaper1200's Avatar
reaper1200 is on a distinguished road
is it better to use the degree method or the other
Quick Reply: Head Bolt Torque Specs. and Sequence
