need help hooking up a transmission temp gauge
Old 03-09-2010, 01:37 PM
Spectreblazer's Avatar
Banned
Default need help hooking up a transmission temp gauge
i do quite a bit of trailer hauling in the summer. i've seen a few members with transmission temp gauges. i need a little insight on how a general hook of one would go
thanks
dave
Old 03-09-2010, 03:20 PM
LRV31's Avatar
LRV31 is on a distinguished road
The ones I remember have a tee fitting that gets spliced into the transmission cooler lines. The temp sensor to the gauge is connected into the tee. You would want to splice into the return line, the one going back to the transmission from the radiator / trans cooler.
Old 03-09-2010, 04:39 PM
Banned
allright is there anyway to verify my blazer has a transmission cooler? mine had the factory tow pkg. (don't know if that helps). sorry about being a newb when it comes to transmission, but its something i've never had to work on to much.
also this would be considered a mechanical gauge then, right?
Old 03-09-2010, 06:15 PM
Every automatic transmission equiped s-series truck has a transmission cooler located in the 'cold' tank of the radiator.
Old 03-09-2010, 07:43 PM
Banned
allright, so if they say it came with a tow pkg. it's just the hitch then, no other goodies?
thanks for setting me straight on that.
also, just searching ebay i found some that are electric, so it has a sending unit.from my understanding i have 2 options, install a sensor on the transmission pan. which would require drilling into it. or the obd2 monitors it. is there a way to use the obd but with a tranny temp gauge. i don't want to go out and buy a scan gauge. im looking to put more gauges in though.
grayman63
07-17-2013 01:56 PM
cody shefelbine
03-12-2013 10:16 AM
zakm0n
01-09-2011 07:31 PM
Malachai
03-27-2010 10:00 PM
mboehler
01-16-2009 07:16 AM
Quick Reply: need help hooking up a transmission temp gauge
