2000 Blazer 4X4 Tranny Transfer Removal
Old 05-27-2010, 05:01 AM
dbrackett's Avatar
dbrackett is on a distinguished road
Default 2000 Blazer 4X4 Tranny Transfer Removal
Good Morning all,
Removing Transmission 2000 Bazer 4X4 for repair have looked at the tranny removal guide elsewhere in the forum. I have everything but the bottom two bolts and cooler lines removed from Tranny and my question is: Can the transfer come with the tranny or does it need to be seperated before I remove the last two bolts and try to bring it all? Seems like it might and that you need to tip the front down to come by the torsion bar cross member, but would like to know before I get it seperated and find out there isn't enough room.
Also is there anything special to get the disconnects to let go on the cooler lines.
Thanks for your assistance
Dan Brackett
Old 05-27-2010, 06:17 AM
The transfer case can stay on or be taken off. It's up to you. Won't matter which way you do it other than how well the trans will stay on the jack.
The cooler lines have a little clip in the quick disconnect fitting. Use an awl or small screw driver to remove the clip and the line should come right out.
Old 05-27-2010, 07:34 AM
dbrackett's Avatar
Default Thank You
Thank you for the quick reply
meatwad63
02-26-2012 07:27 PM
jhood17
01-18-2011 08:09 AM
bfsmith72549
11-01-2010 05:44 PM
razman
04-05-2010 10:15 AM
razman
02-22-2009 01:57 PM
Quick Reply: 2000 Blazer 4X4 Tranny Transfer Removal
