Engine replacement
Old 05-28-2010, 10:08 AM
shwnbrun71's Avatar
shwnbrun71 is on a distinguished road
Default Engine replacement
Does anyone know if I can remove the 4.3l motor in my 2000 chevy blazer and replace it with a 5.7l 350 V8
Old 05-28-2010, 10:25 AM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Take a look at this http://www.marquisphotos.com/ZR2_Blazer/V8ZR2/index.htm
However it have been discussed numerous times. Try the search in the forum and do a little leg work on your on next time. Good Luck T.J.
Old 05-29-2010, 09:12 AM
shwnbrun71's Avatar
I have done a lot of leg work in this and the only ones I can find are the two door blazers or the 2 wheel drive blazer maybe I'm looking in the wrong spots but I have not found a 4 door blazer yet with a V8
Old 05-29-2010, 10:07 AM
Ok, what does the number of doors matter ? I will ask ? What blazer do you have? A 2000 4x4, 4dr right ? Sometimes you have to PULL teeth on here to get info out of Members. We are good, but not Mind Readers,,,, Well Kyle has that gift . What are you looking for specific ?
Old 05-29-2010, 10:45 AM
Phil's Avatar
The number of doors do not matter. Its the same platform. And if you're looking for a 4x4 that has done this swap, then see the link posted above. Remember, anything can be done, there is a Smart Car that has been lifted. Its a matter of how much fabrication, time, money, and patience you're willing to put into things. I myslef have a limited amount of patience lol.
(For anyone who hasn't seen yet and could use a laugh)
Old 05-29-2010, 10:33 PM
shwnbrun71's Avatar
Alright guys you are right I'm just being lazy but I haven't seen a four door with a V8 and when I was doing the leg work for what I have already done. I saw a lot of parts that said not for ZR2 or not for the four door I was just asking if someone had already did what I am thinking of doing and I do have the patience for it and the money and a 350 stroker motor, Life is grand. Sometimes Just asking someone a question can make like so much easier.
Old 05-30-2010, 01:43 AM
Phil's Avatar
No problem man, its what we're here for. Any parts you see that say 2dr only, or except ZR2, etc., are typically either int/ext appearance related things, suspension, or exhaust. Though the exhaust stuff is typically catbacks and vary due to either the undermounted spare tire (if its dual outlet) or because the itermediate pipe is longer for 4dr models (if its single outlet).
Thrakhath
11-01-2011 08:22 PM
dirtbagger
02-25-2009 07:51 AM
badwrench
11-03-2008 04:02 PM
jfire281
03-27-2007 11:06 PM
mikereednv
Engine & Internal
01-26-2007 12:00 AM
Quick Reply: Engine replacement
