pitman arm on a 94 4x4 blazer
Old 06-04-2010, 09:34 AM
ethan.zick's Avatar
ethan.zick is on a distinguished road
Default pitman arm on a 94 4x4 blazer
i need to change my pitman arm any tricks to it?
it apears i neeed to un bolt the steering box because the pitman arm is like 3/4" from the crossmember i cant even fit a wrench to take it off
Old 06-05-2010, 07:43 AM
ohsofly's Avatar
Remove the steering box, there is 3 or 4 large bolts that hold it to the framerail and disconnect the input shaft. You will probably need a pitman arm puller to get it off the steering box splines. Mark where everything was aligned before you take anything apart.
Old 06-10-2010, 12:55 AM
4x4VegasDan's Avatar
4x4VegasDan is on a distinguished road
Do what ohsofly said above. I did mine on my 84 and it was a little tricky. I used a 33mm socket and breaker bar to get the nut that holds the pitman arm to the steering box and then just put the pitman arm puller on there.
Old 07-29-2010, 09:57 PM
michaelross's Avatar
Banned
michaelross is on a distinguished road
I have bought a pitman arm puller online and it really is a great tool. I used to have much difficulty changing the pitman arm but not anymore..
Old 07-30-2010, 07:12 PM
rusty91's Avatar
rusty91 is an unknown quantity at this point
it is like everybody says when your done make sure the idler and pitman arm are the same length from the frame to keep your alignment correct
greatwhite
11-28-2010 11:54 PM
88s10Blazer
12-24-2009 08:43 PM
GMdesigner
08-23-2007 04:57 PM
kornphlake
12-18-2006 02:18 AM
RedOctober
10-11-2006 09:00 PM
Quick Reply: pitman arm on a 94 4x4 blazer
