1997 s10 Tranny problems - no D or 3rd gear
Old 06-30-2010, 09:54 PM
LinkTGF's Avatar
LinkTGF is on a distinguished road
Default 1997 s10 Tranny problems - no D or 3rd gear
No, I'm not talking about a 13-year-old Malaysian hooker I picked up =P
My buddy has got a 1997 Chevy s10 pickup and when he goes to shift it into the Drive gear, it slips when accelerating and instead has to use 1st or 2nd gear constantly, with the 3rd gear also doing the same slip.
He has no check engine light and says the problem's about a year old.
What's the best course of action for diagnosing the problem?
Old 07-05-2010, 08:50 PM
WyldeWannabe's Avatar
WyldeWannabe is on a distinguished road
bump, I the aforementioned friend, I just joined this forum. Help Please...
Old 07-06-2010, 06:46 AM
Start reading through this:
4L60E Information & Common Problems - Compilation
Old 07-06-2010, 09:41 PM
Hanr3's Avatar
Pull the tranny dipstick tube and smeel the fluid, does it smell burnt. If so your tranny is toast.
Is the fluid red or dark in color? Red = good, dark= bad.
Old 07-07-2010, 11:28 PM
Originally Posted by swartlkk
Thanks, I'll check it in the morning
Old 07-08-2010, 07:10 PM
92blazer92's Avatar
92blazer92 is on a distinguished road
i have the same problem, is there a quick fix for this, or only a rebuild?
Old 07-08-2010, 09:36 PM
Hanr3's Avatar
Fix depends on teh problem.
Check the fuse.
Most tranny problems are not in the tranny, typically its an engine performance problem, or a sensor problem.
Old 07-09-2010, 09:37 PM
Well, I checked it, the fluid is okay. I haven't tried to drive it in "D" since last year (I was using 2, my auto trans has P R N D 3 2 1). I recently had to replace the water pump and the v-belt. Now that it doesn't overheat, I tried driving in "D" and it works mostly, it just slips a little.
I really hope this minor slippage isn't severe enough for a rebuild. I hope a quick fix would help. I was thinking about getting a trans flush, but I dont know if thats the answer....also, if a band is slipping, does that require a rebuild...
Old 07-11-2010, 01:52 PM
Hanr3's Avatar
slipping is a problem no matter how small.
flush/fluid change will never fix a tranny problem.
Having said that, replace a qaurt of tranny fluid iwth a quart of Lucas Tranny treatment. It will help the gaskets/seals survive a little longer. Plus it may seal off a small leak which will reduce/eliminate(maybe) the slip.
Quick Reply: 1997 s10 Tranny problems - no D or 3rd gear
