automatic to manual hub swap 83 k5
Old 08-14-2010, 11:47 AM
garciamode's Avatar
garciamode is on a distinguished road
Default automatic to manual hub swap 83 k5
I am replacing my automatic hubs with some manual hubs today. (83 K5) I am also going to replace the wheel bearings while I am there. Any advice on the spindle bearings, SHould I do that too? Also are there any links that show the procedure in case I get stuck,it's been about 10 years since the last time I did this and it was on a different truck.
Old 08-14-2010, 12:36 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
you need a special socket to take off the nut to get to the wheel bearing. there are 2 of them if i remember right. wouldn't hurt to check that u-joint on the axle shaft too. a puller will make easy work of it.
Old 08-14-2010, 04:44 PM
abig84's Avatar
heres a little how to guide on how to tear them apart but i guess it can be read backwards for installation
http://www.midwestern4x4.com/forum/showthread.php?t=549
Old 08-14-2010, 06:47 PM
garciamode's Avatar
Hey thanks for the advice, it helps. I have one side removed and clean and ready to reassemble first thing in the morning. New bearings, grease seal and bearing cups and new Warn premium hubs.The other side should go pretty fast now that I know what I am doing.
Old 08-14-2010, 11:05 PM
you're gonna like those warn . i have them on my truck and they lock and unlock really easy
daveg999
05-08-2012 04:10 PM
old skool luvr
11-28-2009 10:18 PM
trhull
09-06-2009 10:49 PM
BigGreenMonster
08-24-2006 01:32 AM
p_j_robertson
07-05-2006 06:17 AM
Quick Reply: automatic to manual hub swap 83 k5
