door hinge spring
Old 11-06-2010, 08:18 PM
theeviltwinn's Avatar
theeviltwinn is on a distinguished road
Default door hinge spring
Hey all
I have 2 questions but since they are not related I'll start 2 threads. If this is inappropiate please combine them.
Changing the left front door hinge pin, the book says to use the special tool to remove the door spring. The special tool for removing the spring ended up being a pry bar. The problem is it doesn't work for putting the spring back in. I went to the auto parts store and they never heard of such a tool.
So does anyone have any tips on how to get the spring back in place. I'd hate to go to a dealer for this.
Info: 1995 Blazer LT, 4 Door 4WD, Auto, 160,000 mi, 4.3L type W Vortec engine
Mike
Old 11-06-2010, 08:22 PM
It's called a 'Light Truck Door Hinge Spring Compressor'. "door+spring+compressor" will give you the pertinent details. Specifically this thread--> PSA Door Spring Tool
Old 11-06-2010, 08:39 PM
Thanks, that was quick
Mike
(I need to learn to search first)
Old 11-06-2010, 08:46 PM
abig84's Avatar
Harbor freight sells them for like 4 bucks
Old 11-12-2010, 09:22 PM
g_mike's Avatar
g_mike is on a distinguished road
big ziptie, compress the spring in a vice and then do up the ziptie to hold the spring compressed, put the spring in place in the hinge and cut the ziptie.
just a thought, ive never replaced mine but thats more or less how a spring compressor works.
for suspension they use big u bolts.
Old 11-12-2010, 11:02 PM
UberFail's Avatar
UberFail is on a distinguished road
hmmm..... do you need to take the spring out to change the upper hinge? just curious cuz rly my jimmy doesn't even have a spring ffs :/
Old 11-12-2010, 11:48 PM
sctt_wlsn's Avatar
sctt_wlsn is on a distinguished road
found this today after looking all over the forum. http://www.bodyshopzone.com/archives...replace_1.html
hope it helps I plan to book mark that url so I can spit it out everytime someone says the word hinge in here
Old 11-13-2010, 05:16 AM
Those better be some strong zip ties! I used wire and it still took a few tries to get it to stop breaking the wire.
Best to just get the proper spring compressor. Its safer that way!
Old 11-14-2010, 04:08 PM
abig84's Avatar
ha yeah ive done it with bailing wire after compressing the spring in the vise its pretty scary. and even then its kinda hard to get it in
Jorgen
09-28-2007 11:30 PM
saxy37
04-25-2006 01:22 PM
hstt
03-04-2006 12:03 AM
Jetfixer
12-21-2005 02:28 PM
tomsblazer
12-19-2005 03:46 AM
Quick Reply: door hinge spring
