Running lean
Old 01-02-2011, 07:01 PM
badcar's Avatar
badcar is on a distinguished road
Default Running lean
New member.
1997 blazer 4.3, 4-wheel drive. SES light on with codes P0171, P0174.
Have cleaned the MAF, installed new air filter(stock, not oiled), no vacuum leaks, new fuel filter, new engine coolant temperature sensor, cleaned IAC valve. cleaned throttle body, no exhaust leaks. Have sprayed starting fluid around upper plenum and around lower intake manifold gasket area (old trick), but idle did not change. Car idles rough in gear and will eventually stall. Any more ideas? Great site by the way. I have read many posts on this, but I still have not solved this issue.
Old 01-02-2011, 07:32 PM
How does it run with the MAF sensor unplugged?
Have you stepped down through the diagnosis of those two codes?
Old 01-02-2011, 07:37 PM
badcar's Avatar
Thanks for the reply, I unplugged the MAF with engine running and it cut off instantly. Is there a way to check the MAF?
Old 01-02-2011, 07:39 PM
Do not unplug it with the engine running. Start the engine once it is unplugged and see if it runs better or the same. It will throw a code for the MAF sensor.
Old 01-02-2011, 07:43 PM
badcar's Avatar
Thanks will check that tomorrow. Raining here right now.
Old 01-03-2011, 06:56 PM
badcar's Avatar
Update: Pulled out MAF again tonight and cleaned again. Noticed corrosion all inside of the hose making a bad connection. Cleaned all corrosion out of hose and off of MAF sensor body, Installed in car and cranked it up. SES Light went off instantly. Hopefully this problem is solved.
swizznuker
04-16-2010 08:48 PM
Chuck_X2
02-15-2010 07:32 PM
jeeperdad
01-19-2009 08:28 PM
portcqb
09-02-2008 05:06 PM
Tippman7641
02-28-2008 09:32 AM
Quick Reply: Running lean
