how do I bleed my cooling system??
Old 01-13-2011, 05:29 PM
redheadstepkid79's Avatar
redheadstepkid79 is on a distinguished road
Default how do I bleed my cooling system??
94 gmc 5.7 no bleeder screw near water neck, it keeps wanting to overheat. Anyone got any tricks for me to try? Appreciate.
Old 01-13-2011, 08:55 PM
84BlazerS10's Avatar
Edit: Was thinking of something different.
Old 01-13-2011, 10:20 PM
TripleBlackBlazer's Avatar
*MOVED to K5 tech*
With a 5.7 in a 94 GMC I'm assuming you mean full size.
84-I don't believe he's speaking of the a/c system, rather the cooling/coolant/antifreeze system.
I'm not sure if the process is the same for full size trucks, so I just wanted to move this to the right section and clarify.
Old 01-13-2011, 11:13 PM
Yeah, I was kind of half paying attention at the time.
Old 01-14-2011, 09:21 AM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
leave your radiator cap off and let it run, the cap on those should be the highest point in the system so the air should be able to escape.
Old 01-20-2011, 12:39 AM
xmradioguy's Avatar
While doing this you will need to have a large funnel to hold on the top of the rad as it heats up the coolant will overflow into the funnel, if you don't have 1 it will just spill out everywhere. also you can squeeze the upper hose a few times while engine is running, you might have to run it like this and let it cool and run it more than once to get all the air out too.
Old 01-20-2011, 01:32 AM
old skool luvr's Avatar
^^^ yup.
i've also had to pull the upper rad hose off of the thermostat housing, and use a slim screw driver to press open the thermostat until coolant filled the housing. then reinstalled the upper rad hose, and let it warm up.
worked every time in all of my FS trucks.
gsh4386
03-19-2008 08:27 AM
98SmokeBlazer
03-09-2008 11:34 AM
98SmokeBlazer
03-01-2008 08:38 AM
ja2852
Engine & Internal
08-02-2006 02:34 PM
badfxr
07-01-2006 04:22 PM
Quick Reply: how do I bleed my cooling system??
