p0410
Old 01-26-2011, 02:50 PM
01 Chevy Blazer's Avatar
01 Chevy Blazer is on a distinguished road
Default p0410
This code came up when I scanned my car...P0410 Secondary Air injection system fault. My car has been cold, only blows warm air, won't warm up past 1/4, instead of the normal 210....filled up the coolant...know what? Does the code have anything to do with being cold?
Old 01-26-2011, 06:44 PM
rriddle3's Avatar
Excerpted from P0410 Explained:
A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
The code will not clear if these conditions are not met, so yes, the engine temperature can be a contributing factor.
AKYooper
12-27-2013 01:51 PM
ZR 2
08-22-2008 08:27 AM
steveinmd
01-09-2008 10:03 PM
BlazinJay84
12-13-2007 09:38 PM
flyinbrad
Engine & Internal
01-08-2007 11:40 AM
Quick Reply: p0410
