Sas on a 98 s10 blazer
Old 06-03-2011, 10:05 AM
carlosblazer's Avatar
carlosblazer is on a distinguished road
Default Sas on a 98 s10 blazer
Hi, Has anyone used this conversion kit to SAS his blazer?
94-04 Chevy S10 solid axle conversion kit (leaf springs)
i´m thinking of using it cause, as i see, there will be no problem to install a a solid axle to the s10 blazer.
the question is, Is there an axle that you can use to fit in the s10 blazer to mantain the factory rear axle? or you have to change both axles?
in that page they reccomend axles that fit, but i want to know if there´s an axle that you can fit inmediatly without changing the factory rear axle, to avoid changing brake lines, or callipers, etc. to use the factory ones so you don´t have future problems with them.
thanks for the advices
Old 06-03-2011, 05:14 PM
rocpede4x4's Avatar
rocpede4x4 is on a distinguished road
check out the S10 forum, cause there is a build or 2 that is using that kit
Old 06-04-2011, 06:10 AM
abig84's Avatar
Most calipers/rubber lines interchange. Almost everything uses standard thread 3/16th metal brake line
Old 06-04-2011, 10:30 AM
warthogdriver's Avatar
all i have to say is that is one sweet kit...man if only i had done my homework....d'ohhhhh
Old 06-04-2011, 02:13 PM
rocpede4x4's Avatar
the axles u can use a dana HP30 out of a wrangler YJ for the front and the bolt pattern is differnet. u can get an adapter to change the bolt pattern to either axle
Old 06-06-2011, 02:47 PM
skotti's Avatar
skotti will become famous soon enough
Im installing it now. There is no axle that will have same pattern. Im using a wagoneer dana44 front and a isuzu rode rear axle. so far, shock hoops suck. pain in the *** to install. the angle of the shock tabs, and the angle of the shock mount on the supplied leaf mount, not even close to being able to install a shock on it. Ill have to cut the upper mount off and make another. Rest of the kit no real issues. only thing special is right angle drill and step bit
Old 06-06-2011, 03:51 PM
TheRandom1's Avatar
Any pics of the mount/why it won't work?
Old 06-07-2011, 07:37 AM
skotti's Avatar
Im not entirely sure they didnt send me the wrong hoops/constructed wrong, i dont think they could, since it has to be pretty specific for it to fit into the blazer upper a arm mounts. I can try to shoot a pic later tonight. if the shock mounts were in line so the shock was straight up and down, they would work. you would just twist the upper shock hole to match the angle. since the lower mount/spring plate is about 2" or more towards center of blazer. the shock basically is crooked wont even go into the the upper mount
Old 06-09-2011, 09:45 AM
skotti's Avatar
Heres the pics, hard to get a good one. With the angle no way id get the bolt thru.
Shows the angle the shock goes in at.
Old 06-10-2011, 01:54 PM
j89lumaye's Avatar
j89lumaye is on a distinguished road
looks to me as if the hoop is in backwards?
before u go cutting anything, or ordering, or anything try it
it looks as if it would move the top mount maybe 2-3 inches to what im gonna guess is the front of the blazer
Quick Reply: Sas on a 98 s10 blazer
