93' S10 Blazer fuel pump relay locaton?
Old 06-04-2011, 01:42 AM
TheCackster's Avatar
TheCackster is on a distinguished road
Default 93' S10 Blazer fuel pump relay locaton?
1st off thanx for reading! I've heard it's under the hood on the side wall. I was also told it's located in the cab mounted to a bracket on the "cowl". What and where is this "cowl"? I have a 4.3L Vortec MPI engine. My Chiltons book tells just what i stated but doesn't give any information where exactly this "cowl" is located. I think i have a fuel problem and i'm going through process of illimination. 1st i changed the fuel filter and that wasn't it. Next i'm trying to change the fuel pump relay, if that's not it then i go to the fuel pump itself, ughh... Thank God for this Blazer Forum & YouTube. Long live DIY. Thanx again!!!
Old 06-04-2011, 05:15 AM
JerryB52's Avatar
JerryB52 is on a distinguished road
Cool
https://blazerforum.com/forum/1st-ge...talling-59406/
Above link...Check out the advice given to me by Toby Hanson...
Good luck.
Old 06-04-2011, 11:22 AM
ohsofly's Avatar
First off, you dont have a MPFI engine, you have a CPI... In this photo you cant see it, but imagine the photo is wider, it is on the drivers side of that brake booster (the round thing with the master cylinder mounted on it) the relays there will be 2 or 3 of them (if you have AC you have 3) One is the fuel pump, one is the horn, one is the AC... They look like little black boxes about 1.5in cubed... Wires coming out the bottom. The fuel pump relay is the one with the PINK (I think) wire hanging off it thats not connected to anything.
The "cowl" is that cover that your wipers stick out of at the bottom of the windshield.
Old 06-06-2011, 04:02 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
Great Info! I was just about to start a thread asking about the Starter relay. My daughter's 93 Jimmy has A/C and it only has 2 relays. Anyway, the fuel pump took a poop on me last night. So I am also doing the fault isolation by process of elimination. So far, the ECM B fuse is good, I swapped the 2 relays, no change, I'm pretty sure it is the fuel pump.
Old 06-06-2011, 11:39 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
There's a terminal on a wire sticking out of the wire loom along the firewall. That's a direct connection to the fuel pump. Run a 12V hot wire from the positive battery terminal to that terminal. If the pump runs then the pump is OK. If the pump doesn't run then it's bad.
PS- I also have a daughter named Madi.
Old 12-04-2012, 11:33 PM
Brian Nicholas's Avatar
Brian Nicholas is on a distinguished road
Default 93 blazer wont start
they said it was the fuel pump... i changed that then they said it was the spider changed...then the relay changed and it still turns spudders and nuting.... any awsers
Old 12-05-2012, 08:52 AM
chris015's Avatar
Stop. Before doing anything else,use a fuel pressure gauge and check the pressure. These engines are super sensitive to pressure. Turn the key on. It MUST nail 60 psi or more. Then, it has to hold above 55 for 10 minutes. Hopefully you purchased a ac delco pump. Aftermarkets are a hit and miss and these blazers are picky. If the pressure drops fast,its either the spider,leaky line,or the valve in the pump. If it doesnt hit 60 psi you have a weak/bad pump.
You can get a "loaner" gauge from autozone. its free. But you have to leave the retail deposit incase you dont return it.
Tony H
04-16-2014 08:36 PM
upblazer95
03-08-2009 07:15 PM
Lckyctch
12-30-2007 05:38 PM
mytruck2
12-13-2006 04:50 PM
Kellen
09-13-2006 02:15 PM
Quick Reply: 93' S10 Blazer fuel pump relay locaton?
