Which is the A/C low side service port?
Old 06-11-2011, 11:13 AM
ned4spd8874's Avatar
ned4spd8874 is an unknown quantity at this point
Question Which is the A/C low side service port?
As you can tell by the title I'm going to try recharging my A/C myself this time. I'm just confused on which port I plug it into. I'm supposed to connect to the low side, but I'm not 100% sure I'm looking at the right connector. If you look at the picture, I'm thinking it's the one near the bottom of the frame. Where the line bends up to the connector then back down. Is that correct?
Thanks!
Attached Thumbnails Which is the A/C low side service port?-imag0661.jpg
Old 06-11-2011, 12:04 PM
Smaller port is the low side.
Old 06-11-2011, 12:31 PM
kristoph30's Avatar
The low side port is on the accumilator. The big silver coffee can looking thing (Official technical term)
The port on the bent tubing is the high side.
Old 06-11-2011, 04:41 PM
Thanks, yeah I was doing to research online and saw something that eluded to that. I also found that the hose only fit on one of them anyway! I put one can in and it's cold now. How many can's does it take when it's empty? I only put in one.
Old 06-11-2011, 08:44 PM
kristoph30's Avatar
On the evaporator housing should be a label that gives system capacity. My 98 with front air only takes 28 oz. Yours may be different.
Old 06-12-2011, 01:39 AM
killallblue's Avatar
killallblue is on a distinguished road
the 99 takes 1.88 pounds so 3 cans
Old 06-12-2011, 07:01 AM
kristoph30's Avatar
2 1/2 cans. Assuming the can is 12 oz. Dont over charge it.
Old 06-24-2013, 12:15 PM
reyjking1's Avatar
reyjking1 is on a distinguished road
thanks for the info...very helpful
Old 06-25-2013, 05:02 PM
jimspahr@msn.com's Avatar
Go to the ACPROCOLD.com site. There they have a PORT locator. You put in the yr, make, model, and so on of your vehicle and it will send you to a diagram drawing of your port location. It is hard to tell which of the two is smaller and which is larger. by just looking at it.
Old 02-10-2016, 12:16 AM
blazerlt1999's Avatar
blazerlt1999 is on a distinguished road
Thumbs up Awesome advice
Thanks for the info, It is hot as hell down under in N.Z checked a couple of garages out to look at my A/C not working they quoted $200 $127USD without even looking so purchased a can of R-134A and applicator goggles & gloves online for $60 $38usd used the whole can. and is just in the green zone.
The truck immediately started idling better and not surging assume this is the clutch & compressor working normally again, Very happy
Quick Reply: Which is the A/C low side service port?
