Clicking noise behind glovebox
Old 10-26-2006, 11:47 PM
p72lwor's Avatar
p72lwor is an unknown quantity at this point
Default Clicking noise behind glovebox
Now that the weather is colder when I first start my truck there is an intermittent clicking noise behind the glovebox. Sometimes it sounds like the directionals are on. Once the truck warms up it goes away. Any advice?
Old 10-26-2006, 11:52 PM
hillbillyinOhio's Avatar
Default RE: Clicking noise behind glovebox
my guess is that it is a relay clicking on. might be going bad
Old 10-27-2006, 02:34 AM
92teg92 is an unknown quantity at this point
i belive i am having the same kind of problem. to me it sounds like the fan in the blower for the heat...
Old 10-27-2006, 03:05 AM
Blasir's Avatar
Banned
Blasir is an unknown quantity at this point
Do you by chance have a cell phone service with direct connect? If so turn your radio off before you start your truck and see if it goes away. Strange but my Nextel clicks through my radio sometimes for no reason. Or at least I always thought it was the radio.
Old 10-27-2006, 04:30 AM
4lowlife's Avatar
My prevoius '98 LT clicked too. It was a relay. Up under the glove compartment.
Old 10-27-2006, 03:17 PM
lastcoupe's Avatar
yep I've seen this an several 1998 Blazers and Jimmys (yea for some reason 1998 only!). It's the hazard/turn signal flasher module (lower the glove box and you'll see a 1" square (approximately) box with a green zip-tie holding it in that's the culprit.
Old 10-28-2006, 02:25 AM
p72lwor's Avatar
Thanks I'll give it a try.
Old 11-06-2006, 04:21 PM
powwowblazer is an unknown quantity at this point
I changed it and it started clicking worse....I hate that noise..ugh
Old 11-08-2006, 02:17 AM
Blasir's Avatar
Banned
Well look on the bright side, usually the guys on here tell people to change stuff that is a lot more expensive that a silly turn signal relay. Keep asking and soon you'll be doing a complete engine rebuild.
AND IT WILL STILL BE CLICKING!!!!!!
Old 11-08-2006, 04:26 AM
Chevy Lover's Avatar
ORIGINAL: Blasir
OUCH!! What's that?
Quick Reply: Clicking noise behind glovebox
