Wheel Bearing Replacement
Old 10-02-2011, 10:13 PM
tibby's Avatar
Default Wheel Bearing Replacement
I was trying to clarify something so I know for sure. For my 96 4x4, my rear driver wheel bearing is out. When I change it, I have to change the complete hub assembly right? Because you can't just change the wheel bearings? And also, how hard of a job is it to change the wheel bearings out? I doubt I even have the right tools with me.
Old 10-02-2011, 10:18 PM
xgiovannix12's Avatar
wait isnt it an axle in the back ?
or your talking about the front
Old 10-02-2011, 10:23 PM
tibby's Avatar
Default .
Yes, sorry, the front. Lol, that was a moment of dyslexia. I meant you have to change the hub assembly because you just can't change the wheel bearing out in the front right? And for the rear, you can just change out the wheel bearing?
Old 10-02-2011, 10:28 PM
for the rear yes for the front i think you need to replace the whole hub
I cant get any schematics right now since the database is down but ill post one once its up
Edit: This might help you also
https://blazerforum.com/forum/articl...-thread-43645/
Old 10-02-2011, 10:35 PM
tibby's Avatar
Default .
Ok, thanks for the help. I've heard good things about Timken parts. Do they make good bearings?
Old 10-02-2011, 10:37 PM
from the looks of it the bearings come with the hub assembly ill find out as soon as the compnine database comes up
Old 10-02-2011, 11:37 PM
NVANZEE's Avatar
yes, the front bearings are part of the hub. You have to replace the hub as the bearings are not replaceable. and yes timken makes good bearings
davedidit
12-27-2011 12:20 PM
retwizted
11-23-2011 09:01 PM
mikeinwi
24
05-29-2009 12:04 PM
skoot
01-23-2007 05:17 AM
Chavez96
09-20-2006 04:04 PM
Quick Reply: Wheel Bearing Replacement
