98 blazer, oil and water mixed...
Old 10-03-2011, 03:25 PM
98'blazin713's Avatar
98'blazin713 is on a distinguished road
Default 98 blazer, oil and water mixed...
Ok guys, this is my first time at a project of this caliber. So any help, cmments, or advice would go a long way and would be greatly appreciated. I have a 1998 chevy s-10 blazer in which the engine died on the road. It overheated. Got the truck home and checked fluids. Radiator was bone dry, and when I checked the oil, that's where all the coolant was!! So I am in the process of trying to pull the engine. Is it worth rebuilding or just get another?
Old 10-03-2011, 03:48 PM
grizzstang's Avatar
grizzstang is on a distinguished road
IMO that would depend on how many miles it had before the meltdown and how far it was driven while it was overheating. Large amounts of coolant in the oil generally means a boat load of damage.
To me if you are taking it out anyway I would pull the heads off and look at the cylinders and pull the oil pan off to inspect the bottom end. You may get lucky.
Old 10-03-2011, 04:42 PM
Ok so there's possibly a way to repair without removing or am i going the right route? Im stuck at the moment trying to remove power steering pump. And where doing i drain power steering fluid?
Old 10-03-2011, 04:45 PM
xgiovannix12's Avatar
id check over the engine if its worth rebuilding id do it you do have a blown intake gasket
97CountryJukeboxLt
Performance & Brainstorming
14
12-21-2011 08:16 AM
edphot2009
Tires and Wheels
04-21-2011 01:01 PM
chevycrazy2011
01-16-2011 07:06 PM
mrij
12-17-2010 09:39 PM
Quick Reply: 98 blazer, oil and water mixed...
