Headlight connection corrosion
I had to get a new headlight for my 93 jimmy, put the light in. it works, but the high beam doesnt. before the old headlight went out, the high on it worked, so Im pretty sure its corrosion and it just corroded while the other headlight was in keeping its connection. Is there a good way to clean these? I do not want to have to get a new connector.
*edit*
Id use electrical grease on them they will never corrode for a while
Good idea, living in MN, i should probably do that. Thanks!
Thread shouldn't be deleted, this is good advice for any one else having the same issue.
I am glad you got it working again, and for future reference dielectric grease on all electrical connections will assure that moisture stays out, and connections maintain there conductivity.
Thanks again for the tip.
This is even more important if the connection was already corroded. The contacts are plated to protect them from the factory, but once that plating is gone, there is nothing to keep the copper contact from corroding. Using dielectric grease from here on out will protect the contact from here on out.
sledzepplin
08-15-2015 09:13 PM
ziggy888
09-05-2010 08:50 AM
