jimmy just died
Old 12-23-2011, 04:15 PM
Dano01's Avatar
Dano01 is on a distinguished road
Driving the jimmy today and the jimmy just died. Didn't studder like out if gas. Check spark plugs. Can get it running with starter fluid but wont stay running. Fuel pump kicks on. Changed the fuel filter with a duralast one.
Was told it could be a clogged fuel filter. Was wondering what some other things to check. Been driving the jimmy for about 4the days with new fuel filter before todays. Any help would be appreciated as soon as possible need to get it moved from current location.
1990 gmc jimmy 5.7l
Last edited by swartlkk; 12-23-2011 at 07:14 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old 12-23-2011, 07:33 PM
Pump kicks on, but do you have fuel spraying from the injectors? The TBI engines need at least 9psi to operate properly. If you aren't getting fuel spraying out of the injectors, testing fuel pressure as well as testing for power to the injectors would be high on my list of to-do's.
Old 12-23-2011, 08:11 PM
Dano01's Avatar
I disconnected the engine side of the fuel filter and then turned the key on and fuel was not follwoing out of the filter. I am assuming the pump is bad. Going to be changin it tomorrow
Old 12-24-2011, 03:50 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
It is probably the pump. The same thing happened to my old 1990 Blazer, and it turned out to be a weak fuel pump, even though I replaced the fuel filter. Let us know what happens.
Old 12-24-2011, 07:01 PM
Dano01's Avatar
I replaced the fuel pump. Then I had to jump it off and it started right up. I think my battery may be gone from trying to start it so much. will find out tomrrow.
Thanks for all the help.
Old 12-26-2011, 01:19 PM
Dano01's Avatar
I got the jimmy to run after I changed the fuel pimp and jumped it off with my wifes van. I am know having trouble starting it. I get in turn the key to start and it just clicks after about 5 min or so it will start up. After I drive where I am going about 20 min and turn it off it still wont start right back up. I charged the batter and the batter is at 13 volts when the truck is not running I tested it with a meter. I turn everything power wise off.
I was wondering if anybody has an idea on wont could be the problem.
Old 12-27-2011, 06:48 PM
Do you mean the truck will crank, but not start up, or it won't even crank? If it doesn't even crank, it sounds like you have a bad starter.
j_k_auto
01-25-2011 09:12 PM
91Full
10-03-2010 10:10 AM
bobbye
03-18-2009 01:31 PM
Zasder
12-09-2007 09:25 AM
hayndaddy22
11-22-2007 09:53 AM
Quick Reply: jimmy just died
