Changing fluid in transfer case
Old 12-01-2006, 09:49 PM
AutomagicLS1's Avatar
AutomagicLS1 is an unknown quantity at this point
Default Changing fluid in transfer case
Havent looked underneath yet but do they have a drainplug. Also what fluid do you use and is it really difficult to do
Old 12-01-2006, 10:31 PM
Default RE: Changing fluid in transfer case
Yeah, theres a drain and fill plug on the back side of the transfer case. The kind of fluid all depends on the type of transfer case you have. If you have Auto4wd or AWD (rare in a blazer), you'll need to use the GM Autotrak II fluid. If its just the regular push button 4wd, then regular ATF will do.
Hopefully you have a small hand pump to fill it. There really isn't room enough to get a bottle up in there... I used my air hose to pressurize the bottle with a hose up into the fill hole. I really wish I had some 1/4" hose to do it with... The 3/8" hose wouldn't fit and my only other option was 1/8" and that took FOREVER!!!
Old 12-01-2006, 11:03 PM
ORIGINAL: swartlkk
Thanks for the info man thats exactly what I was looking for. Also on the cooler I have my external coolers mounted on my Ls1 in front of the condensor. I bypassed my stock cooler on the LS1. I'm pretty sure the input/output lines to the trans are the same on the blazer right? Input bottom line and output top off the radiator?
Old 12-01-2006, 11:08 PM
You are correct.
Flyfishen
06-18-2019 11:22 AM
Bolbol
03-30-2016 03:39 PM
jamextras
10-13-2012 06:19 PM
AKPerry
10-02-2011 12:02 PM
DaleA
01-13-2009 08:50 PM
Quick Reply: Changing fluid in transfer case
