Low voltage at fuel pump
Old 06-11-2012, 08:54 PM
sick s10 blazer's Avatar
sick s10 blazer is on a distinguished road
Default Low voltage at fuel pump
I have a 95 S10, Vortec v6,4.3,4door, 4 wheel drive. It has low fuel pressure. With a brand new Bosch pump in. So I ck voltage at pump. Its only 8.6 volts. Everywhere else I ck I get 12. What am I missing????
Old 06-11-2012, 10:14 PM
Captain Hook's Avatar
Just a friendly FYI: aftermarket fuel pumps are NOT recommended on 4.3L Vortec engines, AC Delco or Delphi only, unless you like changing the pump
When the ignition is turned to the RUN position, (engine off) the fuel pump is only energized for 2 seconds, so you must check voltage during that 2 second time frame. Have you checked resistance from the fuel pump module electrical connector to ground? Must be less than 5 ohms. Which style connector is on the pump module?
Old 06-12-2012, 07:06 PM
My connector is only a 3 wire. At key turn on I do get the 12+ v. But resistance is around 30.
Old 06-12-2012, 07:33 PM
My bad, 1995, sorry. 30 ohms is too much resistance in the ground circuit, (probably what toasted the old pump). Solder on a 14 gauge piece of wire at the module connector and run it to a good, clean, body ground.
Old 06-13-2012, 10:03 PM
Capt. Hook. Thank you very much. Did that tonite. 1ohm. Hopfully this all works out. Darn tired of droppin that tank.
RJWolfe
02-17-2019 07:32 PM
NV4x4BLazer00
03-10-2012 08:57 PM
2001Blue
12-31-2010 12:16 PM
cjp5
09-15-2010 07:51 AM
c4gibson
04-04-2008 10:49 AM
Quick Reply: Low voltage at fuel pump
