growling in the front
i was out four wheeling and when i was done i took it out of four wheel and went in revers to unlock everything. when i drive forword its making a growling sound in the front end. cv joints look good. IM LOST, its a 2000 blazer
growling in front end
i didnt replace the wheel bearing yet. the front end growles in 2 wheel drive. you put it in four wheel and the noise goes away. is the front end locked up. how would you disengage it.. this thing is driving me crazy. could it still be the wheel bearing.
Sounds like either: 1) the vacuum switch for the 4WD actuator under the battery tray is stuck upen, thereby causing constant vacuum and the actuator constantly pulls on the cable that locks the hubs; or 2) the cable is stuck and not moving back to its "unlocked" position.
I'd pull off the battery tray and see what that actuator and cable are doing.
BFischer
11-29-2013 06:47 PM
JPM
03-29-2009 07:17 PM
ComputerNerdBD
03-18-2009 06:13 PM
