Source for wiring diagrams?
Old 08-23-2012, 01:52 PM
iceman53's Avatar
iceman53 is on a distinguished road
Default Source for wiring diagrams?
I am having problems with a 2003 Blazer involving the warning lights in the instrument cluster. Wiring Diagrams of : power routing, grounding locations under the dash, fuse block to radio connections. tach, speedo,and gauges
don't work, while all warning lights are illuminated. this is my first post so
if I am not doing something right please forgive Me.
Old 08-24-2012, 01:31 PM
Presti7's Avatar
Presti7 is an unknown quantity at this point
Using the search,
this guy had the exact same problem- turned out to be ignition switch plus something else:
https://blazerforum.com/forum/engine...art-now-21756/
this guys 2003 had similiar problems and it was the computer shorting out a relay :
https://blazerforum.com/forum/2nd-ge...tes-etc-47047/
Here is a TSB from GM about losing your dash instrument cluster:
https://blazerforum.com/forum/2nd-ge...-gauges-29188/
Sorry I don't have a wiring schematic for a 2003. Alot of searching and you'll find them piece by piece. The Haynes manuals don't have much for wiring schematics, only the dealer service/wiring manuals you buy from GM.
Good luck!
Old 08-27-2012, 10:00 PM
Ramisclend's Avatar
Ramisclend is on a distinguished road
Would you have a wiring diagram for the 2001 blazer LS 2 wdr with the top glass window section separate bottom rear door. Would the diagram indicate if the tmier is separate from the defogger controller? Thanks in advance for any assistance you could provide
Old 09-05-2012, 06:06 PM
iceman53's Avatar
Default Found it.
The cause of all my problems was a loose connector on the dash cluster.
Pin A9 was wallowed out.I re-crimp it and all's well. I found the wiring
diagrams I needed to at Tradebit.com. $19.95 for a manual that covers 1994
2005.
rick1toknow
11-24-2014 10:54 AM
Dolt_Dodger
12-05-2013 12:27 PM
Unlimitedsp
09-21-2012 12:52 PM
Greed
12-11-2008 12:31 AM
chevyrocksu
01-03-2007 03:04 PM
Quick Reply: Source for wiring diagrams?
