Ignition timing too high
Old 01-17-2013, 04:03 PM
Fosse's Avatar
Fosse is on a distinguished road
Default Ignition timing too high
I just picked up an 89 Jimmy. I went to get it smogged today and it failed because the ignition timing is too high at 800 RPM and they said it should be at 600. Is there anything I can do to fix this or do I need to take it to a mechanic? Also the engine has been replaced with a 383 if that matters
Old 01-17-2013, 07:21 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Is it carbed or does it have fuel injection.If its carbed you need to lean your air fuel mix.You can adjust the timing also.Need more info about the year of engine and if and how its been modified.
Old 01-18-2013, 04:01 AM
Fosse's Avatar
pretty much all i know is that it is still throttle body injection like the original 350 and it has vortec heads. i probably should of got more info on it when i bought it, but i needed a vehicle right away so i bought this one. and it runs amazing. just this one thing i have to figure out
Old 01-18-2013, 03:31 PM
70-K5's Avatar
70-K5 is on a distinguished road
Are you in Oakland, CA? I thought they had strict rules about engine swaps...
Anyways, the ignition timing is a relationship between spark and pistion position. You said that it needs to be at 600rpm vs. 800rpm, that is a idle setting.
My $0.02 is take it to a mechanic.
Old 01-18-2013, 03:48 PM
Fosse's Avatar
Yeah California. As far as I know engine swaps are fine, just can't put a carbureted engine in a vehicle that didnt come with one.
Old 01-18-2013, 05:49 PM
You can advance the timing which will increase the idle speed.You have to plug or disconnect the computer cant remeber which hopefully some can help with that.If its not a timing issue it could possibly be tps.
AndrewO1991
06-04-2013 04:59 PM
drblaze
18
06-22-2011 01:58 PM
MuTaLiZeD
05-01-2011 02:27 PM
RIFLEMAN 308
07-31-2010 03:42 PM
97 POS
03-31-2010 10:41 AM
Quick Reply: Ignition timing too high
